tntcorvette
My car will not start and im looking for help.
I recently replaced my entire ignition system and found the car not to run. I've got a msd 6A, MSD coil & matching msd bushing, accel cap & rotor, holley ignition module, msd 8.5mm spark plug wires and a set of a/c delco spark plug wires. Everkything is new and installed correctly. I've got the timing set correctly and all.
Today I pulled the spark plugs and found them to be black & 2 of them were just about fouled. Looks like I was running rich (due to a looser not connecting my mat sensor and me driving the car 50 miles, but thats another story).
I put in new plug wires and did a leak down test on the injectors. They seem fine, but I do notice that the car will not hold fuel pressure for long (turn ignition forward and the pressure jumps to about 40 then falls back to about 25 in a couple of minutes, if that).
After putting in new plugs I tried to start the car and it still wont start. I can hear popping out of the mufflers as if it wants to start, but it wont. I've disconnected the MSD and it still wont run, so thats not the problem.
Anyone have any ideas whats going on? Even if my injectors were leaking like there was no tomorrow the car should start right? I have no codes because I disconnected the battery terminal while working on the car.
Where should I start? I've been through the hanyes manual and everything seems to be as it should.
BTW, this is on my 85 corvette.
ad
