L
leannes89vette
89 vette..
whenever it rains i have to cover the back of the car so no water gets into my tank. my drain always clogs!!! when this happens its is very hard to start. well a few weeks back it snowed here and i forgot to cover it and when the huge amount of snow melted of course it went into my tank.! the car now wont start. its sounds like it wants to and on the first trun of the key a white smoke comes out. its smells of moisture. but then its just wont turn over. its not the battery or teh alternator or anything else. my questions is , how do i get the water out of the lines. we siphoned out all the bad gas in the tank and put new gas in but i think the lines that are up in the engine are full of the bad gas because it sounds like it wants to start still but wont. we unscrewed the fuel line and at the same time turned the key to get the fuel pump going to get any bad gas out of the lines and then connected it back. it still wont start due to the fact there still may be bad gas in the injectors or etc. i want to know what i can do . i know on cars with carbs you would use a starting fluid. but where this is fuel injected what would i use. or unless anyone has any better or easier ideas first before we start getting into removing the injectors or etc. any advice will help. if i keep trying to start the car will the bad fuel eventually burn away???????? 89 vette
