PD2
Hi all!
Been a while since I posted anything here, but, I've recently been trying to go it alone on working on my Vettes. The one I have is a 1963 with a 327, 250HP that has a Carter's WCFB. Back when I was having a "known" mechanic and classic car restorer help me, he told me that the carb I had was the original and was at the end of tuning and tweaking and just needed to be replaced completely. So I purchased a NOS rebuilt WCFB 250HP carb from Corvette Central.
Today I installed the carb and left all settings as is on the carb. I also cleaned the manifold area really good and installed a new carb gasket that I also got from Corvette Central. After getting everything back together on the carb and linkage all back in place, I cranked up the car. Started and ran fine at first, but this is where my problems start.
Once the car was warmed up to just shy of 180, I tried to adjust the idle speed screw to get the idle RPM's to idle around 750 or so - it jus would not idel unless I kept on the gas. After it would idle - if you want to call it that as it was ROUGH idleing. The car idles like it has a high-lift cam in it and really shakes the motor in the motor compartment. I tried to adjust the idle mix screws a little but never really noticed any change in the way the car idled. When I'd clear the car out by reving up the motor I'd get a few small backfires and during WOT the tail pipe dumps puffs of black smoke. The carbon monoxide smells a little like it would be rich - fuel like - but the fuel smell is not normal, so to speak. It smells almost like old fuel or something. I don't know how to explain it fully.
Basically, I need so very basic, newbie type help with getting this new carb setup to run smoothly. I'm not very familiar with working on carb, engines or the like and I currently own three shop manuals that don't give me a ton of information on how to set the screws - well, it does but its telling me to hook up tachometers, vac gauges, and things like that which I do not have.
If anyone can help me through this I'd greatly appreciate it. Again, this is a newly rebuilt carb from Corvette Central so I'm assuming that the carb is not the issue here. Fuel gets in the barrels just fine and when the car is off, no fuel is leaking into the barrels (this was something that was happening with the old carb). Choke operates correctly - in fact, even better than the old carb. Open up when heated and closes up when cooled down. I'm not sure what else I can tell you, so please ask questions and I'll try to fill in any gaps as necessary.
Thank you, in advance, for any and all help!
PD2
PD2
