indycallaway
I am throwing lean exhaust O2 sensor code on the car. I put the scanner on it on Saturday and pulled the codes out. Cleared them and today took it for about a 30 min spin all through the rpm range and no check engine light.... any ideas? Should I not worry about it until it throws the code again, or go ahead and replace the O2 sensor? Also gave the VSS (vehicle speed sensor) code but I knew about that because the speedo quit working last week... any ideas on that? Thanks in advance!!!
