Help! CHECK RIDE CONTROL????
CHRLDO
PITTSBURGH
1992 BLUE COUPE
NO EXPERIENCE WITH RIDE CONTROL.WHERE DO I START? 92 COUPE WITH 90 K MILES. FUSES OK
Buy the factory service manual. You need it for the SRC diagnostic and repair information contained in it.
Like Hib said you really need to pull the codes. The FSM will take you through the steps. If you can pull the codes I'll check in my FSM for the problem.
I have been through this already. I had to have my actuator and shock both rebuilt. Cost $110 for the actuator and $140 for the shock.
thank you! if i dont get the manual first , ill be in touch.
I should add that CAC is on the verge of posting a comprehensive tech. article about SRC....history, how it works, parts availability and service issues.
Figure on it going up sometime this month.
Who did the shock rebuild?
