- Joined
- Jan 1, 2002
- Messages
- 7,243
- Location
- Washington, Michigan
- Corvette
- '67 Marina Blue Convertible
There are a number of variables to consider, but I don't care for the "mirror-finish" on the flywheel; have never seen a flywheel done that way before. Flywheels are surfaced on a machine like a Blanchard grinder, not a lathe, and should have a surface finish much like you see on a brake rotor.
I would agree that the heat damage is probably a result of slippage, which is normally associated with the linkage adjustment not providing adequate pedal free play. Free play ensures that the clutch is fully engaged and the TO bearing isn't touching the fingers, and is the primary criteria for linkage adjustment.
Two other factors to consider are 1) The TO bearing installation on the end of the clutch fork, with both the fork AND the anti-rattle spring in the groove on the bearing - it can be installed wrong (see below), preventing correct free play adjustment, and 2) Using the correct TO bearing - all Corvettes use the 1-1/4" bearing, NOT the 1-3/4" bearing used on passenger cars and trucks.
