Big bat
New member
My 2003 stalled one day. a few days later would not start. It came down to low voltage from ignition switch. Clean up contacts worked fine, how ever the traction display and service engine soon could not be deleted even with a scanner. The code that comes up is C1248 and C1254. What can be the causes for the C1254? I had replaced the ignition switch, the scanner still will not clear the codes and remove the traction service soon display, also what is the steppes to use the on board scanner? Thank You
