I asked this question before and did tests to my car like I was told.
I tested my airpump, fuel vapor purge solenoid and the egr solenoid. My egr valve works. I even checked my air valve that is under my ASR motor. All are checking fine when I test them for ohms. They even click when I pull the codes.
The problem is when I drive the car on the freeway and as soon as get off the freeway and coast to stop the check engine light comes on and stays on. If I drive the car around the streets for a while and shut it off, and restart it after 5 minutes or so. The light turns on and stays on. What is wrong? The dealer won't touch my car since it has an aftermarket chip. Thanks in advance.
-Jeff
-Jeff
