CROOZ1N
I hope that I've solved this one too. I sometimes will get a check engine Light which freaks me out every time as nothing good happens when that light comes on.
So anyway the code has been 32 EGR.
Sure enogh last weekend i got the check engine ligh tfor about 20 minutes it went off and didnt come back.
So Tuesday I pull the EGR valve off looking for carbon build up. The valve came off suprisingly well for a car w/117K on it. The gasket wasnt stuck and came right off and the bolts were not even super tight as youd think they would be.
Ok so the pintle looked fine no build up.
BUT I put the vacuum line back on and tried to make the valve actuate. The elbow that goes to the valve would not seal. I replaced the elbow with a straight piece of hose I had laying around. Its pretty cobbled up right now but I hope it takes care of the code 32.
I'll replace the elbow as soon as I can find one but meanwhile I will run it to see if the code doesn't come back.
Is there a way to clear the codes without unhooking the battery to see if the same one comes back?
