C
CharlesBrown
Having a cold start issue. Car will cold start but it's not very happy about it. This just started. Before, would start right up and run at fast idle 'till warm and then slow down as it should. Now, on cold start, it chokes and coughs but in a few seconds will run at the higher rpm with no further trouble. Reading in my FSM, they talk about a "cold start valve." But I've also read that the '84 Vett was the only one that has one. But they do mention it in my '88 FSM and show a picture, but I can't find it where they show it i.e., attached to the drivers side fuel rail. Question: Does the 1988 have a CSV? If so does the above sound like a problem a defective one would cause? If neither of these could be a problem would the next place to look be the Throttle position switch?
