Vmrod,
There is no pink wire plugging into my wiper motor, light blue, black and yellow/white, and they are all on the driver's side of the motor.
There is a pink wire that comes out of the wiring harness at the same point these three wires come out, of a slightly heavier gauge, that goes up under the distributor shielding and then on to points unknown.
Also, I'm looking at the 1977 Electrical Troubleshooting Guide and don't see a pink wire in the Windshield Wiper/Washer circuit. In reviewing the schematics, it appears that there are pink wires from the ignition switch that goes to the fuse box if I read the schematics right. There are also pink wires that come from these two sources and to the:
Fuse box
Radio Noise capacitator (I think that is what the pink wire I am refering to is for as it goes toward the distributor and aren't these things part of the ignition circuit????)
Turn, flasher and backup lights
Power Windows
Cruise Control
Seat belt, headlight and ignition key warning
Tachometer
Parking brake light
Generator warning light
The car is hot right now so I really can't play around under there but if this is the wire you are looking at, I'll see if I can trace it further tomorrow.
Hope this helps. I'm far from knowledgable about electrical circuits but I think I can handle the color thing, no promises though:confused
Bob
