TCC Solenoid
Tatortot,
Last night I worked my TCC problem. I tried ordering the correct TCC solenoid for the 81 vette (AC Delco 1997591), but this part number is discontinued, and I could not find it even at
www.gm-restorationparts.com The dealers kept sending me to a tranny shop and the tranny shops sent me to the dealer...:crazy
Instead, I had to order the TCC Lock-up solenoid (AC Delco P/N 1997592. If you have access to a 81 Corvette Shop Manual, then you can see in page
7A3-15 that the alternate solenoid looks like the solenoid wiring for TH350C model 8VZ, 8VA,8T3...etc at the upper-right corner of the page. The alternate solenoid costs around $50.
Well, page
7A3-14 at the very first paragraph, tell us that the model code is stamped IN the right side of the bell housing. I looked all over, but I could not find the model for my tranny. So I turned it in my mind every which way I could and then it occurred to me that the alternate part number solenoid that I had to settle for and my stock solenoid were only different in that the negative wire (black) and the "D" pin wire (so identified at the tranny plug connection) were crimped together on the alternate P/N solenoid. My stock solenoid had the negative wire and the "D" pin wire separate from each other.
So, after searching for locking wire terminals similar to the stock ones and not finding any at the usual places (Auto Zone and the like), I decided to reuse the terminals on my stock solenoid. I clipped the ones from my old TCC solenoid and I also clipped the alternate solenoid wires to match my stock solenoid. I used No-crimp connectors (by Swenco) to connect them to the alternate solenoid.
I then installed a new 3rd gear switch (AC Delco P/N 8643710) to make sure that I would not have to go back to the tranny pan drop process in a while. I then wired the transmission valve body as it was as stock. For which, by the way, I could not find the exact configuration in the shop manual.
Not trusting my brain power :duh I also installed a B & M tranny oil pan drain kit -in case this repair did not work. It will make my next pan drop less messy. I also had a bit of a scare when my last pan bolt felt like it was stripped.
I regained my composure, and used a tap die set to chase the threads with a 5/16 -18 die. (or is it a tap? :confused ). The stock bolt would not work anymore, but a longer one (1" long from Auto Zone) did. Luckily it was at the shifting cable plate hole where it stripped, so the excess lenght was taken up by the plate itself.
I am glad to report that the transmission is shifting fine and my problem is gone. I think that the reason was that the stock solenoid was installed with a gasket, and the gasket was leaking (the solenoid surronds a small hole on the tranny valve body). If the gasket leaks, then you'll experience a delay in the lock up where it seems that the gear changes and then the converter locks up (it sounds very much as if one were to let go the clutch (in a manual tranny) at low RPM for a thrid gear. The alternate solenoid, by the way, has a built-in rubber seal instead of a gasket to seal between the solenoid and the valve body.
Now what remains is for me to follow Evariste's instructions to by-pass the TCC lock-up for whenever a Mustang pulls up next to me
. The best of both worlds -TCC lock up for fuel economy and By-pass TCC for fixing Mustangs....
:L
