coolant expansion tank renewal...
Motorcity USA
1973 L-48 Coupe
can i save it or do i buy a new one? bubba sprayed it black along with most everything else....i have most of it restored but i dont seem to be having much luck with this jug. it has wrinkel lines in it that the paint remover dont seem to touch....i have tryed steel wool and remover .. i would like to make it bright again or im gonna get new.
thanks for replys as usual. Chas:w
If you were only using a harward store grade of paint remover, you might want to step up to an automotive/aircraft grade paint remover such as TalStrip. Charles
where am i gonna find it?
do i need to go to painters supply for the good stripper? i think i have bix or something like that....thanks for the tip.:beer
Most of your automotive paint stores for sure and some of the better automotive parts houses will carry it or an equivilent paint stripper. Be sure to get cha some good chemical gloves. Charles
Sorry but all of us 73 owners are a bit out of luck on this one. That tank yellows over the years and all of the chems in the world will not get it to looking new. You may be able to get the black paint off of it but it will then be a dingy yellow. And there is not a correct 73 expanson tank in reproduction. The 73 tank is a one year only piece as there is a bump in the fender well behind the tank and the tank is molded to fit over that bump. 74 and later do not have the bump in the fender well and their tanks are molded smooth on the rear. If you use one of the 74 and later tanks it will not lay right.
Only hope is to find a very good used one. Good luck.
tom...
