RonnieH
I have a very small coolant leak - experience tells me small leaks only become major headaches in time. My Vette is an '89 (27,000 miles). Anyway, there is some type housing on the intake just below the thermostat housing. It is just to the driver's side. One of the alternator support brackets is just above this housing. There are 2 torx head screws in this housing. I can see very small amounts of coolant bubbling from under this housing. I am at a loss as to what this housing is. It looks to be an integrated part of the intake, but I can see a seam/gap from which the coolant is leaking while under pressure and there are the two torx head screws holding it down. Can anyone explain what this housing is and what can be done to eliminate the leak? I would guess it is more than merely tightening down the torx screws. If the screws need to be removed/tightened during this process, what needs to be removed for easy access to the screws.
I would like to flush the radiator, but doing that before correcting the leak would only cause the leak to worse after cleaning out the system.
Thanks for any help you can provide.
