cooling fans stay on
C
CLABORN1960
Hello all, a quick question. My cooling fans stayed on this evening when I turned off the car, It is a 93. I removed the fuse to the primary fan and they went off or it went off..... What do I need to replace?
Any feedback will be appreciated......
vigman
Motor head!!!!
Valencia, CA,USA
Fan relay
Is probably STUCK on
Vig!
vigman
Motor head!!!!
Valencia, CA,USA
Relay Location
On radaitor shroud Drivers side... 2 relays one for main one for 2nd
Swap em... see if the problem moves
Vig!
C
CLABORN1960
cooling fans cont'd
Okay I put the fuse in this morning drove to work, was planning on getting the relays and put them on at lunch. I turned the car off when I reached the job...... the fans go off like they are suppose to. My other question is this, are the fans suppose to come on independently of the engine? I had a porsche once and theirs did, also a VW jetta back in college and those fans would come on whenever...... This is the first time this has happened with my vette..... so is this normal?
vigman
Motor head!!!!
Valencia, CA,USA
Not on a VETTE
Once you kill the key... the relays will drop ( unless there have been MOD's)
Vig!
S
Shadowing1985v
hmm
i think the fan draws its juice before from the alt before it hits the battery
so with the engine off the fan would shut off
not 100 percent sure though
i have mine on all the time,, wired to the bat
