F
fabio
Hello guys,
So I just got this 75'Vette and I'm doing some work on the cooling system, I'm planing to put a Edelbrock aluminum pump, a 180degree thermostat, get rid of the cluch and install a 18.25" flex fan. Anyone have tips for me?
I'm kinda confused by the cooling system, this is my first chevy and it seems to be really messed up. :ugh
Besides the radiator hose there are two other exits on the water neck, one is closed with a plug and the other has a small tube with two connections, both closed with rubber caps. What are these suposed to be?
On the other side of the intake there are another exit that I thougt would go to the heater but the hose turns around on the ac compressor and connects back to the water pump. What is that? is it pumping hot water back to the engine?or cool water directly into the intake?:W
Some one knows where I can find a diagram or something that actually shows all the hoses and fluxes in the cooling system? I have a Haynes maintenance manual but there is not much there...;help
Thanks a lot guys,
Fábio.
Thanks a lot guys,
Fábio.
