Has anybody replaced the timer for the interior lights. Mine is erractic. My tech book from the factory shows the location but no step by step. Help!!!!!!!!!!!!!
HI there,
It is really just a plug and play type set up.
It is taped up to the wiring harness, under the passenger side instrument hush panel.
Usually, it is tough to get to. And its around the ecm harness, and you might be able to just slide your hand in between the wiring harness for the ECM, and the lower heating duct.
Besttoyou, c4c5
