greydbj
- Joined
- Nov 24, 2001
- Messages
- 59
- Location
- Orleans, Ontario, Canada
- Corvette
- 1981 Charcoal Grey; 2009 Black Coupe
I have a minor problem (hopefully) that I am sure someone else has seen and probably has a solution.
I started the car tonight and the courtesy lights and dome light went very bright, then very dim and then normal; it did this for three cycles and then stayed on and would not shut off in the 30-40 second cycle controlled by the timer. I had to pull the fuse to get them to turn off, but have lost a couple of other things, like the power door locks and I am sure the theft deterrent. The behaviour of the lights, it bright, dim, normal for three cycles is almost reminiscent of a voltage regulator problem (in the old days), but I have had a recent test of charge rate etc and all was okay; maybe not now.
Anyway, I am sure it has something to do with the interior light delay timer; the shop manual describes the trouble shoot when the lights will not turn on, but not if they will not shut off; is it the same test.
Has anyone had a similar problem or any suggestions. Tracing/tracking electrical problems is not my forté, so any and all help I can get would be appreciated.
Thanks.....dbj
Thanks.....dbj
D
