D
dudeboy
Hellow all, I am new here but here goes, I am trying to change my fuel filter on a 1987 convertable. that car comes with a cross member to hold twisting down, it bolts at the chasi that also mounts the fuel filter,there is two bolts to the bracket to frame. one bolt came out fine, the other one is spinning so I cant hold the nut to remove it.This nut is a blind nut that screws tight on installation, this one didnt,(this is factory install) there is no way I can see to hold the nut to unscrew it. I am sure sombody else encountred this situation before, if someone did and could let ne know how to remove it, I would be indebeted to you forever. Thanks Larry
