JohnGrawcock
- Joined
- Sep 22, 2003
- Messages
- 318
- Location
- Kokomo, IN
- Corvette
- Claret 82, Light Bronze 84, and Black 69 Vert
The idle on my 82 coupe is out of control. When I start the car the idle goes to 3000 or 4000 and ramps up until I turn the key off. I'm hoping someone will have a suggestion to help solve this problem. I've done the following:
- Verified that the throttle plates on both TBI units are fully closed
- Verified that no trouble codes are set (reads only 12)
- Verified that there are no vacuum leaks
- Checked operation of EGR valve
- Verified adjustment of TPS
- Unplugged both idle air motors. Idle did not change.
- Replaced gaskets for both trottle bodies and the upper plate of intake manifold as suggested by GM service bulletin.
The only thing I've found that brings the idle down is blocking the air intake ports at the top of the throttle bodies above the idle air motors. This makes me think that the motors are not restricting the air flow enough to control the idle. The fact that both units behave the same makes me suspect the controlling signal rather than the motors. Does anyone have any suggestions or the information necessary to debug the IAC circuit?
