Last summer I engaged the cruise control on the '81 a couple of times, and it worked fine. Yesterday I tried several times to get it to work with no luck.
I see very little trouble shooting help in the Haynes manual. I've checked the vacuum lines and wiring. I did change the carb, re-adjusted the cruise cable. The wife did pump the brake pedal for an hour or so when I flushed out the old nasty brake fluid. Could something under the dash have given up? Any trouble shooting tips would be greatly appreciated. :confused
