V
vmrod
Well guys,
another vehicle has caught my eye, and I believe that this may be the time to let go of my vett. I will post pics of it later on to this thread.
This '77 is a custom convertible. A whale tale spoiler and LT1 style spoiler has been installed, but can be removed. There's a 82 style rear bumper on the car as well.
Engine: Aftermarket 350. Stock bore. Oversized valves. Dart II Iron Heads. New 750 Edelbrock Carb. Edelbrock RPM Performer Manifold & Edelbrock street performer Cam. Spring kit inside distributor. High output coil & module. 8mm wires. Custom loom. 14" air filter.
S.S. lined o-ring type brake calipers. S.S. braided flex lines. New brake bads.
New fiberglass monospring. New VBP strut rods. New gear differential brace cushions. Rear trailing arms professionally rebuilt including rotor run-out. New driveshaft bushing. (poly) All new heavy duty driveshaft and half-shaft U-joints. All new KYB gas shocks. Great tires. New 4" hooker sidepipes with spiral baffles and JetHot coated with heat resistant metallic coating.
Interior: '82 seats. (will give up original 77 seats as well) All new heat barrier and sound barrier (2 separate leayers). Anti-rattle window cushions. Carpetted.
Know problems.
1.A/C non-functioning. (no compressor, but should have the brackets)
2.Engine starts to overheat during hot summer. (due to nice-looking custom fan. Either stock fan or larger fan will remedy this.
3.Small transmission leak. (2200-2800 torque converter has been ordered and front seal will be replaced.)
Will take $9k right now OBO. I will start working on the repair list, and the price may adjust depending on the task completed.
Thanks,
-Vic
(vmrod_2000@yahoo.com)
[img=http://img163.imageshack.us/img163/9608/1exterior2060rz.th.jpg]
[img=http://img95.imageshack.us/img95/9571/2exterior2064az.th.jpg]
[img=http://img219.imageshack.us/img219/9747/engine2067yj.th.jpg]
[img=http://img219.imageshack.us/img219/2383/hatch2067lz.th.jpg]
[img=http://img219.imageshack.us/img219/2707/interior2061ab.th.jpg]
(last edited for adding pics)
Know problems.
Thanks,
-Vic
