wishuwerehere82
- Joined
- Sep 6, 2003
- Messages
- 2,316
- Location
- Rochester, NY
- Corvette
- Red '82 Coupe,Sebring Silver '98 Coupe
You have 1 O2 sensor located below the the passenger seat on the exhaust system. It has a connector to the Purple wire on the end of the sensor. Unclip the connector and remove the old sensor out of the exhaust pipe with a box wrench and replace it with a new one. It's around $36.00 for a new one and easy to replace.
The O2 sensor is wired directly to the ECM which is located in front of the battery. So if changing out the sensor doesn't fix it, you may have some oxidized contacts on the two connectors that go into the ECM.
I get 24.6 MPG on my '82, if that gives you an idea about what a ballpark figure is.
The IAC's are on the front of the Throttle Bodies, they are round gold colored cylinders about 1-1/4" in diameter with wrench flats on them. There are connectors clipped to them. They easy to replace also, but a little more expensive than the O2 sensor. Just unclip the connector, unscrew them with a large wrench(or channel locks) and replace with new ones and clip the connectors back on.
