Viet Nam Vett
- Joined
- May 28, 2004
- Messages
- 2,410
- Location
- Egg Harbor Township NJ
- Corvette
- 65 BB 502 Cp /MSD ATOMIC EFI/ 2009-HUMMER H2
I Have the numbers from my 65 Vette's motor which is up for sale now. I am going to post the numbers in a few min.. Went to check them and I am getting conflickting info ...How about a read here.. John Z or Some one with a book??
Ok..This site says the block casting is Corvette only for this year if it is from Towanda...My Block Casting is..#3858180....1964 to 1967. Read the foot notes about this block.. http://rowleycorvette.com/vettestats.html
"Tonawanda cast small block V8 engines normally use the last two digits (example: "62" for 1962), and these castings were not used in Corvette production except for the 1965 327 cubic-inch with 3858180 casting number. "
My Cyl Head Pad # is TII02HC.... Now the HC Should mean ...327cid 4bl Carb 67-68 Passenger Car .... WTF????
The Casting Number on the Driver Side Cyl Head Is #"8782461" and undernieth it says "J2964" Don't know what this year or application Is......
Do You???
Also I found this other Number..3846563...?????
Thanks...
Do You???
Thanks...
