You really gotta' get savy with a vette...
The ECM is under the hood, right in front of the firewall driver's side, above the battery. 4 harnesses plug into the backside of the ECM. You have to follow each harness for a foot or so, until you find a couple wires that head for the framerail just below it. Where they attach probably has corrosion. Hit them with WD40, loosen them, spin the ring connector loose, spray again, and tighten.
You really need FACTORY Shop Manual, not Chiltons / Haynes. And a multimeter. If not, mechanics will take your money. ALL OF IT - especially for electronics problems.
Electricity flow is just like water through a hose - just harder to see leaks. It doesn't flow through the wire, unless it has a place to go. And it can be IN the hose, but still won't flow...
And one more BIG difference - they don't TASTE the same, especially to the organic analog battery tester! Higher voltage = louder holler :L
