jamiewh
New member
- Joined
- Oct 22, 2020
- Messages
- 1
- Location
- Boynton Beach, FL 33426
- Corvette
- 2008 Z51 Coupe, 2005 Coupe, 2000 Coupe, 1997 Coupe
My 2008 C6 Z51 Corvette won't quit running when the STOP BUTTON IS PRESSED. The gauges all go off but the engine continues to run for a short time, about 15 seconds. The battery also gets drained in a couple of hours if left connected. My OBDII scanner reports NO TROUBLE CODES FOUND. The red light next to the Accessories light, on the START/STOP SWITCH stays on too. What could be causing this?
I've already replaced the START/STOP SWITCH WHICH DIDN'T HELP.
I've disconnected the Alternator B+ terminal from the battery, as well as the wiring harness from the alternator.
Nothing appears wrong with the alternator. Nothing changed with the alternator disconnected. It is charging normally.
