O
Oldskool153
So im thinking i may reconnect my OD and wire in a switch as many of u have sugested, at that point I should be able to control it even if the closed loop threw the ecm isnt closed? like for example I have a bad 02 sensor so it breaks the closed loop with a fault code and my OD starts actin funny when i let the ecm control it, with a switch i can still manually control the OD engagement disengagement even if the closed loop circut is broken right? my next question is how hard is it to do this? and does it involve my removing the transpan>? or can i go right to the wires on the shift switch?
