macx
I'm finally getting around to finishing my plans for a mild upgrade on my 81 I bought a few years ago in preparation for some trips after I retire.
I'm working on a mild upgrade that will yield better throttle response but also good mpg's preferably on 87 so I can afford those trips. The big items are a basic tuneable throttle body efi system that I already have and a vacuum style distributor to go along with it because it won't use the electric engine control, a mildly beefed 200-4R and 2200 converter which is pretty much a bolt in, aftermarket Vortec style heads and dual plane intake, and a mild cam somewhere in the 210@050 intake range with lift a dab under .500 along with roller rockers, a 3" main single exhaust pipe with a hi flow 3" cat, and 3.31 gears. Should give me 300+ torque under 2000 rpm and about 1750 rpm or so at around 75 mph.
In order to run 87 I'm working on gathering info on the stock pistons, which appear to be a nearly full recessed dish in the crown which is not good for detonation resistance. I had hoped to avoid tearing into the shortblock, other than for a cam, as it's in good serviceable condition, but if I can't achieve a decent quench situation might have to.
The one thing I can't pin down is the stock deck height dimension.
It calculates out to be about .045" depending on who's statistics I go by. I know the block height, piston compression height, etc, so can figure it out from there, but am somewhat surprised in all the existing statistics I've found there's no listing of the stock dimension of how far down the piston is in the cylinder.
From what I know so far, I'll likely go with 67cc heads which would give me around a 9-1 ratio or slightly less which would be fine if had some quench surface on top of the pistons which it doesn't appear that I do. So might have to replace the pistons, which means machine work, and parts that wouldn't make sense not to replace if I have the engine out and apart, which I had also hoped to avoid. That's why I want to make sure of what's in that engine stock for pistons and deck clearance. I only want to do this once!
I had figured on running a flat tappet hydraulic cam to save over the much higher costs of a roller setup, but if I have to replace the pistons it might pay to check to see what I can get for a good used roller shortblock that has quench style pistons stock, if there is such a thing.
Decisions, decisions!
Thanks for any info!
