ParisTNDude
I am convinced it would have been easier to pull the engine than change the water pump on my 84 Vette. You have to dismantle the front of the engine, take the passenger side valve cover off, disconnect fuel lines and wrestle every piece off the car. I broke the aluminum bracket for the AC compressor and had to have it welded and at the end, had one long bolt and one short one left over????? Yes, I took pics before I started, but do you think any of them showed where this one piece went???? (no way) It cranked and ran fine (quiet, what bliss) afterward, but on the first drive and after 5 minutes driving, it looked like we were spraying for mosquitos.....yep, right side valve cover gasket didn't hold and I had to pull that apart again. What started out as an imagined 3 hour chore ended up taking the better part of 2 days...dang! Defect to Russia before you ever try this at home!!!
