Fans are by-passed to run all the time so that is not the issue. You could be right about the thermostat.... or one better it may be removed altogether - it is behaving more like that than anything else. Only 103,000 miles on the car but of course, would still definitely flush the system with all new radiator.![]()
There is the theory that with no thermostat at all (if that happens to be the case) that with no restriction slowing down the water flow at all, the water doesn't spend enough time in the radiator to cool down. It might be worth it for you to start cheap and simple here and install a new thermostat without doing anything else yet and see what happens from there?
