1KLRTOY
My 01 is showing the dreaded Service traction and active handling can anyone tell me what might be the cause,could it be the abs module??:confused
Thank you Todd for you reply. I have in fact have checked the grounds, I've taken the 4 under the hood loose used a dremel w/a wire wheel to clean the frame, used a dielectric compound along with a toothed washer torqued them to 70 lbs in and even cut the connector off on the drivers side and soldered them to a lug. I did not cut the pass side because the wires are very hard to strip and solder, I did clean the connector on the pass side but it looked clean as they all did. The codes remain and only show up every 6-8 cycles and can be cleared but remain as history codes. I also show a BCM 0432 & SDM 1040 I don't know if there related. I had the same problem about 3 yrs ago and the dealer replaced the EBCM module and that fixed it, so maybe a call to the abs fixer is in order. If you have any other ideas let me know, thx again.Here is the deal. I would check the two ground plugs behind each of the headlights for corrosion. These plugs have 6 wires and attach to the frame with one bolt. Undo the bolt and pull the male end out of the bottom of the plug. If you see green corrosion on the pins, use a wire brush and clean them off and reinstall. You can use some WD-40 on the pins to keep moisture out. The service traction control code should not reoccur. When left unchecked, it may reappear and also give you a reduced engine power in the DIC and you will have to pull over and wait a few minutes. Erase the code after your done.
