Did I Screw up the Rear Spindle Bearing Housing?
Wilkinshc
New Mexico
1965 Coupe
I disassembled the rear trailing arms and I dropped the bearing housing. Is it ruined?
Chuck
Nope. All you did was bend the dust shield which needs to be replaced when changing bearings. I have them in stock.
Mike
Thanks for the reply, I thought it might be the seal but I didn't see a seem. Must be the years of crude.
I checked your site out, I will keep you in mind it the future. I plan on sending these out to Tom's Differential, I plan on using his offset trailing arms with upper control arms, 35 spline spindles, and 1480 u-joints.
Thanks again.
Chuck
