S
slashnick
I have been having the problem of my lights on my dash going out and the signals and high beam indicator comming on. I sent my dash out for repairs and have since got it back. When I reinstalled it, it worked fine for about 20 minutes, then went dark. Once again the high beam and turn signals were illuminated.
Since I just had the dash repaired I figured it was the grounding wires that came from the 32 pin connector. I cut the 2 grounding wires (D1 & D3 ) and ran them to a new grounding point.
Still no lights. I tested the new ground by removing it and when I did so, the high beam and signal indicators went out, when I reattached it, they came back on.
Do I need to run a new ground from the 24 pin connector too? What else could be the problem?
Thanks.
Thanks.
