Just got through taking out the cluster and putting it back in. Spent a while on it since i'm no mechanic.After spraying the male and female contact pionts with Q D Electronic Cleaner, Digital gauges still not working!:bang Is there a fuse that can stop the Gauges from working or should I use the electronic spray on one of the connector's under the hood?
The Gauges show as following. "Coolant oF"
"Oil Temp.oF"
"Volts ----"
Thanks Eddie Tee
"Oil Temp.oF"
"Volts ----"
Thanks Eddie Tee
