c4c5specialist
Technical Advisor
HI there,
Oil windage is due to the fact that oil is still slung around the crankcase, vapor with oil droplets is still present that is pulled into the PCV system for burning. Many people believe that this is the ONLY factor with carbon fouling of the intake valve, this is incorrect.
If PCV vapor was the only issue or a major issue, you would have a wet, droplets forming on the valves, not a dry carbon chunk type residue that is what we are addressing in this post. This wet, droplet formation would therefore coat the valves and you would never see this dry carbon deposit, ONLY WET.
This is why understanding ALL factors shows us that catch cans, cold air induction, fancy services with heavy repair bills are just NOT needed.
Plus if you have the dry sump system, you have a HUGE catch can on your car already, the oil sump tank itself.
Allthebest, Paul.
Allthebest, Paul.
