krscholz
Yesterday, I fitted the hood on my 75 C3 with the Performer RPM and this is what I found. There was 1 ½” space at the front of the air cleaner and 3” at the rear after the hood was closed. To check clearance yourself, take a wad of aluminum foil and compact it loosely into two balls and place one ball on the front and rear on the air cleaner. Then close the hood carefully. Open the hood, assuming that the hood closed all the way. Take out the foil balls and measure the compacted area. This was done using the full size 14” Edelbrock Elite air cleaner, but in all fairness, I must say that I used the flat air cleaner gasket instead of the ½" plastic spacer that Edelbrock recommends when you have an electric choke. The way to get around the electric choke problem, is that I took a small ball pein hammer and created a little more space on the lower lid where the choke tucks-up under. This gave me the space I needed so that the lower lid could sit flat on the carburetor and it is impossible to see when the air cleaner is installed.
For even more space, I’m going to use a NAPA Gold #6037 filter element instead of the Edelbrock element because it is 2 5/8“ compared to Edelbrock’s stock 2 7/8”. When you call Edelbrock and ask about the clearance, they will say that the Performer RPM will absolutely not fit Corvettes. Here is the reason I believe for the misinformation: early C3 Corvettes have flat cowls/hoods except for the high performance factory set-ups. Later mid-year models have a substantial cowl for their air induction system that was later developed like my 1975. The newer cowls give more clearance that works just fine with the Performer RPM. If you're nervous about the engine torquing too much, you may also switch to a pair of Poly motor mounts that give la little more rigidity to the engine. Feel free to contact me at www.c3corvettegrilles.com for any questions. I hope this helps.
One other point. . . If you are going to an Edelbrock Performer RPM intake, you won't want to use the stock air cleaner, this may add to the compatibility problem that Edelbrock is talking about.
UPDATE: I just changed the air cleaner to allow for the electric choke clearance. This Eldebrock part is slightly higher and still fits fine (model #4221).
