E
evolution
Wow, that NPG+ stuff looks kewl. How hard is the conversion process? Do you have to flush and dry out the whole water jacket/radiator or just get as much as you can out?
Category: Coolants
Bulletin No. 01.010
Date: 01/12/01
Replaces: 96.009
Introduction:
Equilon (owned by Texaco® and Shell®) markets a European coolant technology (OAT) that consists of ethylene glycol inhibited with a combination of sebacic acid and 2-ethylhexanoic acid supplemented with tolyltriazole. It was originally called "Long Life", but a lawsuit brought by Warren Oil, who markets a fully formulated coolant under the brand name "LongLife®) forced the retraction of that term from the DEXCOOL, Texaco and Caterpillar® packaging. The combination of a mono and dibasic carboxylic acids permitted Texaco to obtain a patent on the specific combination. Other companies have obtained similar patents, by varying the mixture somewhat and by using similar, but not exactly the same, chemistry.
General Motors® has been using this coolant technology in their cars and light trucks since the start-of-production of the 1996 model year vehicles (except Saturn®, which began in 1997). GMC® medium trucks equipped with Caterpillar engines, have been getting a nitrite-added form of DEXCOOL (NOAT) to insure protection against wet sleeve liner cavitation-erosion.
Frequently Asked Questions:
Can DEXCOOL organic acid antifreeze be mixed with ethylene glycol antifreeze?
It is ethylene glycol based antifreeze! The concern with mixing comes from the fact that there are very different chemical inhibitor packages in use. Most leading technologies will work very well when used as intended, typically at 50% in good quality water. If the coolants become mixed with DEXCOOL, however, one study showed a possible aluminum corrosion problem in certain situations. The other question is a concern for dilution of the protection packages. At what mix is the there too little of either inhibitor to protect the engine? As a precaution, both GM and Caterpillar instruct that contaminated systems must be maintained as if they contained only conventional coolant.
How long will it last?
Uncontaminated, the engine manufacturers instruct that it may be kept in service for 5 years or 150,000 miles in cars. In trucks, Caterpillar and GM currently recommend that the nitrited version of the coolant be run 300,000 miles or 2 years, re-inhibited with a nitrite-tolyltriazole "extender", and run to a total of 600,000 miles.
Are there different brands that meet the spec?
Yes. Any brand displaying the DEXCOOL trademark meet the spec, others advertising compatibility are from the same family of coolants.
How can a customer tell if he has DEXCOOL?
If the customer owns a GM car and has orange coolant, then its DEXCOOL! In GM trucks the coolant is "orange- red", indicating that it contains nitrite. Orange coolant in Daimler-Chrysler® vehicles is NOT Dexcool. (Daimler Chrysler owners with orange color factory coolant should consult their owners' handbooks).
Does it protect aluminum?
Yes, even though it contains no silicate, the primary aluminum protector in conventional antifreezes, published data shows that it protects aluminum.
What are the advantages of DEXCOOL compared to the previous GM 6043 factory-fill?
Compared to old-fashioned phosphated antifreeze, it may be more stable and improve water pump life. Evaluations of the two technologies to compare their respective service lives has found them comparable. In fact, a Ford Motor Company study concluded that organic acid coolants do not offer any significant advantages for the consumer over current North American coolants. In a modern car with a well maintained cooling system, current North American and OEM factory fill coolant corrosion protection can be extended far beyond previous expectations."
What are the disadvantages?
Higher cost, possible incompatibility, limited availability.
Is it environmentally safe?
It is ethylene glycol based. It is toxic. While it does reduce coolant waste, it is not environmentally safer than conventional EG coolant.
How can you test it?
Use a refractometer to test the freeze point. The inhibitor levels can not be cost effectively tested. If in doubt, throw it out and start over.
Should we recommend that Pencool® 2000 or Pencool 3000 be used with Dexcool?
Penray does not recommend the use of Pencool in Dexcool coolant.
Pencool® is a registered trademark of The Penray Companies, Inc. Dexcool® is a registered trademark of GM.
Interceptor430 said:I too want to say I never want to step on any toes intentionally.
I also put lots of faith, time, and $'s in GM vehicles.....I also do
old Fords...and do them myself with proven chemicals and parts.
100K on a car is no big accomplishment - regardless of what chemicals is inside.....but $30K for a GM truck, 4 years, and 70K+ miles, and a GM service tech telling me the intake is leaking because of the Dexicool (on a vehicle that They maintained, and
with GM original stuff) did not set well with me.
Bad service people?...uh hu...at an hourly rate of $65?
Yep...GM printed all this verbage, advertised all the info about a coolant that can go for 5-6 years....100-150K miles....on this new
super duper chemical called Dexicool.....it just amazes me that
they would make a big tado over $12 worth (2 gallons) of coolant
and worse yet, that so many people (including myself at one time)
believed the damn hype and trusted it.....only to get (as I said),
4 years and 70K+ miles later (out of warranty, naturally), and be told I have an intake leak because of their coolant.
Check and change your oil and filter often($25 every 3k miles if using regular oil)....check the coolant often, change it every 2 years with the proven Green stuff($12).....and check and change the auto tranny fluid, burn good premium gasoline, change the gas and air filters too.....
Take care of it.....
Ever see a Ricer with 200-300K miles on it? There are zillions of them on the road....(hint: they don't use Dexicool, use regular 87 gas, and regular oil, and I'd bet most of them have nasty air filters).
LT1 and LT4 guys....check the Evans site for instructions that are
specific to your engines.....be totally informed before making a decision on this, or any product.
Take care of you
[Ever see a Ricer with 200-300K miles on it? There are zillions of them on the road....(hint: they don't use Dexicool, use regular 87 gas, and regular oil, and I'd bet most of them have nasty air filters).
I have owned two Z cars that both lasted well past 300,000 miles and were running strong.. I changed my oil at least once a year,,ie 7-12k miles..
I am however concerned about this coolant thing. My Vette has the orange coolant, I assume it is the dexacr**. I suppost after reading this I will consider changing it. Is there any benefit to the Dex... coolant?
Hi there,Interceptor430 said:Well Hello there c4c5specialist,
Sorry to read you obviously took such offense to my comment ref what you said......or was it what you did NOT say?
Sir, I do respect and honor your written word, so if I offended you in any way directly, it was not intended.
What you DID say, is NOT what I've read in any GM manual.
Care to tell me the book and page number that says run a water hose to the engine and try to clean out the gel and bad dexicool that undertrainned and incompetant Goodwrench people at
$65 per hour do?.......
Care to tell me that the Dealer Service and Mech Rep didn't tell me
my '97 intake coolant leak was NOT caused by the dexicool and that they would be happy to repair it for a mere $500?....
Care to tell me why GM would print so much info on Dexicool that it is a 5/6 year 100-150K mile coolant that Buyers of GM products
won't have to worry or be concerned about what is maybe $12.00 of fluid?
Care to tell me why GM prints in there manuals that regular type oil can stay in the engine for up to 7,500 miles? - But -the Service Department says to be sure and do it every 3K miles or 3 months?
Every one has their opinions....GM prints one thing - the Service Reps say otherwise........GM installs Dexicool - the Dealer Service Reps and Mechs say it caused a $500 problem.
Yes, I was, and remain very interested in your personal opinion and what you care to relay as the best thing to do. Obviously, by you're own written word, you have different ideas ref what should be done, what has been done, and what should be done.
If I stepped on you toes, I do apologize. If it became obvious to you or gave you the 'feeling' that what you have said is incomplete, inaccurate, or misleading, it should then be upon you to post a new thread to describe in one final and correct and believable description about the proper use and dependability of
Dexicool. If your feelings got hurt, well not many people give a damn about feelings when the subject involves our Corvettes. It is clear, concise, accuracy that comes not from feelings, but from Thinking!
Until such time that I am no longer able to think and question what are supposed to be Facts, I will continue to be in charge of what I do, have learned thru my experiences, my $'s, what has always worked correctly and flawlessly in my 12 vehicles, and will
spread the word when I have been lied to and misled by GM (your employer).
It's up to you to either explain this issue with detailed logic (thinking), or let me(and everyone else) read what you 'feel'.
