Distributor Sheild
jimbil208
pa
1982 collectors edition
Hello
On a 1982 cross-fire ,can anyone tell me where the black plastic shield mounts. I just got a shield and it looks like I need to move wires just to get it in.
Thanks,jimbil208
i know that they had one but i have never seen one mounted. most have been removed .take pics when your done.:w
It fit around the top of the distributor...on the rt side(pass)
the leg goes in front of the dip stick for the tranny...behind the block,
covering the distributor wires....seem to me I had to unplug the several groups of wires the get the past,on both sides.and the hood latch goes thru the rings on the top.
Thanks Bill
Actually I meant was where does it bolt on,or what holds it on.
Thanks,JIm
It doesn't bolt on it fits over the top of the distributor,with a 'clip' if you will towards the front of engine.
Hello
Thanks,jimbil208
Do you have the Assembly Manual? It shows the installation.
Spark plug cable retaining ring; sounds like you need one. The ring installs on the tops of the plug boots; ignition shield clips onto the ring.
Hello
I bought a high performance distrubtor cap and the ring does not fit on it. Therefore the sheild wil not fit.
So does anyone need one?
Jim
