A
		aaron1
I have been cruising the archives on several forums about DIY Camber strut rods. There seems to be conflicting info on whether you should lower the inner mounting bracket.
Norvil said that he modded his bracket and lowered the holes 1-1/2 inches. This would make the strut rods parallel with the 1/2 shafts when sitting at normal ride height. He had some photos posted.
Two others said that you want to sandwich two pieces of 1/4 aluminum plate between the mounting bracket and the diff. One said that this would be the best mod you could make!
Herb Adams book said lower it 3/8 of an inch.
And another person said "Absolutely do not lower the bracket, because then you will have zero camber change". ?:confused;help
Unless I misread ....:W
Also what if you are using the factory rear y-pipe? there is a heat shield that bolts to the bottom of the bracket. by lowering bracket would this interfeer with exhaust piping?
Thank You for your help!
Aaron1
Aaron1
