Help! Dome doesnt work when door is opened but works when headlight switch is turned back
samm
mascouche
1981 candy apple rocket
Im trying to diagnose my door jamb switches.I have a 1981 corvette.white,blue,beige wires connected to driver switch and blue and white on passenger side.my dome light goes on when headlight switch is turned backwards but not when i open one of the doors.
any suggestions and where can i test for power first coming in.;help
check the door switches
if you have service manual you will find schematics in there!!:thumb:thumb
Hello Samm, i'm sure it's time to change the courtesy light relay control(delay timer).It 's positioned behind the glove box on the right side.
The courtesy delay timer is a simple fix and the pin switches in the doors should be checked as well. I did mine and I am no mechanic so, its all pretty straight forward. The schematics in your manual make it fairly easy.
Based on my 81 shop manual TS section; Door switches only provide a path to ground, which activates the delay timer & to turn on the Ctsy Lights. The two door switches only provides seperate ground paths to activate the delay timer. The timer gets power from the 20 Amp Gages Fuse, pink/black wire and on the orange wire from the "CLK, CTSY 20 amp Fuse". If power at timer checks good w/ a test light, at the timer connections. Plus other wire connections at the timer are in good condition and the black wire (gnd) is verified good, also dis-connect and reconnect the connections at timer. If this doesn't correct the problem, then the timer become the prime failure suspect. A good rule of thumb with older electrical connections, always dis-connect, check for dis-colored, burnt, broken, deformed, contaminated contacts, etc and always double check all recent work areas for security & correctness.
Hope this long winded input makes sense and provides some helps.
