M
		mdsbch
I am replacing the door panels on my 85 coupe and have a couple of questions.
1) When I removed the old door panel, there is something like a bead of caulk that goes around the metal under the door panel. Is this there to help keep the panel tight against the frame? And if so should I remove it and replace it with fresh or can you just use what is there, and if not should I just remove it all?
2) While I have the door apart, I cleaned up the mechanism (plastic strip with teeth and the rail it slides on) that runs the window up and down. Now I'm assuming it probably should be re-lubricated, but what should it be lubricated with? I don't want to use something that is going to attract dirt and grime to collect and gum it all up again.
Any help would be greatly appreciated. Thanks.
Mike
Mike
