E
Eagle85C4
I noticed the other day that the security lamp in the drivers info panel was no longer working when the drivers door was opened, but that the interior light were working.I removed the panel under the drivers side dash and found a light blue wire hanging. Hmmmmm so I then unscrewed the switch and it had three wires to it, a white one, a tan one and a stubby piece of light blue wire. I then noticed that the white wire was chaffed and exposed. Seems that over the last 17 years the switch working in and out caused the wires to chaff and finally broke the light blue one. I soldered and taped the wires back together. The trick was putting it back in, you have to pretwist the switch in the opposite direction of install, clockwise. All works fine now.
