mjlisz
Active member
Hi folks,
I am trying to get the driveline support beam and propeller shaft off in preparation for engine/transmission removal on my 1990 C4 L98 six speed. Can anyon help with a few questions?
1) I have taken everything around the gearshift lever off inside the car. Does the gearshift lever itself need to come off or can that stay on?
2) When removing the driveline supprt beam, how do get a wrench above the it to keep the nuts from turning (on the front)? The back looks doable but I can't seem to get a wrench on top of the front of it.
3) Should the propeller shaft slide out without removing the beam? I can't seem to get it out with the beam in place.
4) What holds the transmission in - only the support beam?
5) Can you remove the engine with the exhaust manifolds on?
Thanks for your help.
Mike
Mike
