Hey there .
I have a 2006 C6 and need to replace the Door latch tucked away inside the pillar , my question is on a scale of 1-10 how tricky is this job for a shade tree mechanic? , My biggest concern would be getting the latch pulled out and then having a night mare getting the release cables removed in tact from the latch and then getting them seated properly in the new unit.
1) how many cables are connected to the latch ? I know of the trunk cable and the floor mounted one is there a third from the door button itself?
2) is there a common problem with the latch mechanism that can be repaired instead of replaced ( trunk release and floor release work fine but door button and key fob and outside handle do not
any advice would be appreciated
