And getting worse.:ugh 2001 Coupe, 23,000 miles and no codes. Usually slamming it will help. It was 45 this morning and it didn't start working till above 60. What needs to be replaced, window switch maybe? Thanks for any help.
Mark
Mark
Found a couple of article on another site:
"If you are referring to the "don't use it, you lose it" passenger window rolling down, than this is a known issue with C5s. This can be easily resolved without replacing regulator. Simply remove the small cover behind the inside door handle and taking a screwdriver with a hammer, lightly tap on the screw head while pressing the down button. This worked for me.
It is also advisable to roll down the window on a regular basis to keep it in working order.
If this does not resolve your issue, there is a video out there that shows the regulator removal and installation process. In line with the other reply, this can be located by doing a Google search.
Hope this helps."
If you are going to replace the regulator there is an excellent set of instructions:
"Do a google search for vette essentials (custom interiors). There is an installation instruction button on the left hand side of the screen. Select that and then select the section for installing door handles. It will give you step- by-step instuctions on removing the door panel (to include all of the tools you need to do the job)."
Mark
Same happened to me. Was in denial and went after every electrical connection I could find that had any connection to the window. Finally replaced window motor. No need to buy entire regulator apparatus. Problem solved. Go to USAUTOPARTS.com My motor was $46.15 and so is yours, I just checked. Good luck.
Dave
