Rcurry23
I went to the ATM this morning and when I went to roll up my window, it did nothing. So I opened the door and shut it, and it rolled back up. I never thought any more about it. Then I went out at lunch and started it, rolled the window down some, (just to make sure I don't lock the keys in the car while warming it up). Went to the car wash and rolled it back up. Then stopped by to pick up some lunch at a drive through, window went down fine, now I can't get it up. Nothing works on the drivers switch panel. The passengers works fine with its switch. Just nothing on the drivers switch. I did a search and saw something about wiggling the rubber boot for the wiring loom. Tried that, and nothing. Now what?!?!? Remove the rubber boot from the door jam, and check the wiring? Remove the door panel? Don't know what to try next. I'm stuck at work and its COLD out!
