M
Michael79
A question from across the pond.
While blasting around our quaint country roads I noticed my oil pressure drop from 55psi down to 35. Given that I was in 4th gear at 5000r.p.m I backed off immediately and nursed the car home. Subsequent firing shows an idle pressure of 25 psi and a death rattle of a probable spun bearing.
The engine is (was) an L48 and had less power than the Iraqi Republican Guard ( and not as fast going backwards) so apart from a huge pain in the wallet the loss of the engine isn't catastrophic.
I've been offered a new 383 with all the goodies, dyno'd @450 bhp and 480 lbft. If I do this swap into my 4 speed manual, standard clutch transmission when I hit the loud peddle will I
1. Put down two looong strips of Goodyears finest..or
2. Put down 200 lbs of GM's finest gearbox and differential all over Her Majesty's highway?
Assuming the answer is 2, what's the solution, and remember I'm in England where everything is 3 times the price you lucky guys pay.
