Greg C
- Joined
- Jul 9, 2003
- Messages
- 102
- Location
- Ann Arbor Michigan
- Corvette
- 2000 Convertible;Bowling Green Metalic
Just picked up our 1st Corvette (2000 Convert. with LS1 engine, Automatic).
Have to order a set of shop manuals yet but did find the info on the DTC Codes. Took a look......here are the ones I found......
58-SDM: Code- B1001H (could not find this one on the list)
AO-LDCM: (Left Door Control Module)
Codes: B2282H (Battery #1 Fault)
B2285H (Battery #2 Fault)
U1064H (Loss of Communication with BCM)
A1-RDCM: (Right Door Control Module)
Codes: B2283H (Battery #1 Fault)
U1064H (Loss Of Communication With BCM)
BO-RFA: (Remote Function Actuation)
Codes: B0605H (Receiver Internal memory Malfunction)
U1255H (Serial Data Line Malfunction)
U1096H (Loss Of Communication With IPC)
U1016H (Loss of Communication With PCM)
All the others showed "NO CODES" (I assume this is a good thing)
OK, now this car had only 1234 miles on it when I picked it up.
So I am going to assume that all the codes except for the one under 58-SMD (Code #B1001H) are because at some point the vehicle's battery went dead do to sitting in storage and not being driven alot. All system's communications were loss due to loss of power from the battery. Hopefully someone will see this post and verify my line of thought here (at my age any line of thought is good).
Next question: What does the "H" at the end of each of the codes mean? The list does not how any H's.
Last question: What does the 58-SDM code#B1001H mean?
Thanks for your time in helping a "newbie" to the world of Corvettes.
PS: Sure is a hoot to drive.
Polo Green, Oak Interior & Top, Performance rear end (3:15 gear), Active Handling (wish it had the active suspension...that would have been neat but begger's can't be choosers...well you can up to a point anyway)
Convertible, memory pkg,......I guess everything cept the CD changer and the active suspension...even has the Magnesium Wheels (nice touch appearance wise).
Anyway thanks for your help.
Greg in Michigan (the "newbie")
