delray56
Hi All,
I bought my first Corvette, a 62 Roman Red convertible (4 speed), this past summer and am installing a Tremec 600 transmission this winter. I have torn down the engine to see what's inside, even though it was running great. It was an original 327 / 340 HP car (has the 6500 rpm tach) but the engine code of SA indicates that it is a replacement block (casting code 11/61). I'm new to the group and would like opinions on whether to put an original spec cam in this engine. It has high compression pistons, double hump heads, and aluminum high rise intake. The cylinders are bored .040 over, and the crank is ground .020 / .020. The crank pilot bushing bore was only 1.065" OD, and was messed up, so I'm having it bored out to fit the standard 1.090" OD pilot bushing.
The pistons and bores are like new so I'm simply replacing rings and honing the block.
The cam specs are unknown and it is a hydraulic lifter type. I'd like to bring the engine back to original performance with the addition of the Duntov cam and solid lifters. Crane makes the cam currently. I am curious as to driveability vs a more mild cam. I'm not afraid of adjusting valves every year. Any insights are appreciated. Can I reuse the old pushrods with the solid lifters?
Dave B in Ohio
Dave B in Ohio
