- Moderator
- #41
- Joined
- Feb 25, 2002
- Messages
- 4,316
- Location
- Cleveland, Ohio
- Corvette
- ZZ4, 700R4, Steeroids rack & pinion, VB&P Brakes
He's just triple double-checking to be sure.Been saying that for weeks/months.![]()
The conversation is half the enjoyment!![]()
Thanks. It might be worth checking. Although when I tested the t-stat, it seemed to open as far as it could goI had a similar problem, is why I ask about the therostat. It also work fine in the hot water. I finally removed the thermstat and started the car. It restored the cirulation. The thermostat was bad, causing a restriction, I guess it was not opening all the way causing presure to build. Hope it helps. I did not intend a nasty remark if that is how you took it.
I was also told the same by a mateThis is one of the nicer forums. Some of the corvette forums they can get nasty fast. They will answer your questions with do the search function with comments. Still they have some good info. Good luck.
I understand how I could piss somebody up with just too many similar questions, although for me they are all worth an answer![]()
So you mean the closest to the radiator? The ring at the very end of the pipe seems to be much thicker than the one near the radiator, so I have the clamp placed there instead at the moment.Between the radiator and the ridge.
Does it really matter much? I guess the most important thing is to get it secured strong?
It seems like the best thing to do. I really must find out what's the brand of this radiator. Right now I think it could be one of the Rockauto.com 3rd party brands, since that's the place where most of our US parts retailers order stuff. This one seems to be a possibility if looking at the photo: SPECTRA PREMIUM Part # CU717.now i understand why it blow off, never seen one like that either. i would think it would go on the thinner part of the neck but to be safe i would just put two on it.
